Sketchucation Tools 5.0.4
Sketchucation Tools 5.0.4 is available
Download
Release Notes:
- New UI/UX Web dialog
- Progress and notification changes
- Licensing activation/releasing
- Improved update notifications
Toolbar icon will now indicate updates to extensions. If you do not has Sketchucation Tools toolbar enabled in your workspace it will self-enable when you have updates pending.
There's a new Quick Menu to get to common settings and features
Licensing has been integrated into the Sketchucation Tools dialog so you can quickly activate and release licenses.
Bundles now show current device and cloned Bundles making migrating to new device or SketchUp versions much easier.
Lots of other tweaks and improvements under the hood too.
Added in 5.0.3
Control the prompt to update notificationsAdded in 5.0.4
- Better toolbar toggling and update notifications
R Rich O Brien pinned this topic on
Version 5.0.1 released. Minor bugfixing
Hi:
I just installed Sketchucation Tools 5.0.0.
Now I get this. Nothing loads on this page.
Clicking on Continue does not resolve the issue.
Any suggestions?
John -
@hydrokiwi what version of SketchUp?
V5.0.1 is broken
Extension Errors Report SketchUp: 25.0.660 OS: Windows 11 Ruby: 3.2.2 Extension: SketchUcation (5.0.1) Error: ArgumentError (invalid byte sequence in UTF-8) c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:805:in `block (4 levels) in getMyPlugins' c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:804:in `each' c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:804:in `block (3 levels) in getMyPlugins' c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:798:in `each' c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:798:in `block (2 levels) in getMyPlugins' c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:796:in `each' c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:796:in `block in getMyPlugins' c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:751:in `each' c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:751:in `getMyPlugins' c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_loader.rbe:99:in `<module:SCF>' c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_loader.rbe:13:in `<main>' C:/Program Files/SketchUp/SketchUp 2025/SketchUp/Tools/extensions.rb:197:in `eval' C:/Program Files/SketchUp/SketchUp 2025/SketchUp/Tools/extensions.rb:197:in `require' C:/Program Files/SketchUp/SketchUp 2025/SketchUp/Tools/extensions.rb:197:in `load' C:/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/SketchUcation.rb:173:in `register_extension' C:/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/SketchUcation.rb:173:in `<module:SCF>' C:/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/SketchUcation.rb:17:in `<top (required)>' -
installed per instructions - fail. uninstall, close SU, open SU, get warning to install, install per extension manager - looks ok. close SU, open SU, get error ^^^^^^
as a note, i've checked my login on web site - ok so any internet calls "should" be working (in case this is an issue retrieving "getMyPlugins")
This is a previously unknown, and so far inexplicable, error.
How many Plugins folders do you have set up ?
Do they all have .RB files in them ?To find a list can you please do this:
Open SketchUp
Open Extensions > Developer > Ruby Console
Copy/paste this as one line:
puts "\nDefault:\n#{Sketchup.read_default("SCF", "DefaultPlugins", "???")}";lp=SCF_Dialog.getMyPluginsFolders();puts"\nAll:\n#{lp}\n\nContents:\n";lp.each{|p|puts Dir.entries(p).size-2 };puts"\nRBs:\n";lp.each{|p|rbs=[];Dir.entries(p).each{|f| rbs<<f if f=~/rb$/};p rbs.length};puts;Press enter
Copy all of the returned lines and paste them into a reply.
v 5.0.1 returns similar error )-;
Extension Errors Report SketchUp: 25.0.659 OS: macOS 26.0.1 Ruby: 3.2.2 Extension: SketchUcation (5.0.1) Error: ArgumentError (invalid byte sequence in UTF-8) /users/USERNAME/library/application support/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:805:in `block (4 levels) in getMyPlugins' /users/USERNAME/library/application support/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:804:in `each' /users/USERNAME/library/application support/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:804:in `block (3 levels) in getMyPlugins' /users/USERNAME/library/application support/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:798:in `each' /users/USERNAME/library/application support/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:798:in `block (2 levels) in getMyPlugins' /users/USERNAME/library/application support/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:796:in `each' /users/USERNAME/library/application support/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:796:in `block in getMyPlugins' /users/USERNAME/library/application support/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:751:in `each' /users/USERNAME/library/application support/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:751:in `getMyPlugins' /users/USERNAME/library/application support/sketchup 2025/sketchup/plugins/sketchucation/scf_loader.rbe:99:in `<module:SCF>' /users/USERNAME/library/application support/sketchup 2025/sketchup/plugins/sketchucation/scf_loader.rbe:13:in `<main>' /Applications/SketchUp 2025/SketchUp.app/Contents/Resources/Tools/extensions.rb:197:in `eval' /Applications/SketchUp 2025/SketchUp.app/Contents/Resources/Tools/extensions.rb:197:in `require' /Applications/SketchUp 2025/SketchUp.app/Contents/Resources/Tools/extensions.rb:197:in `load' /Users/USERNAME/Library/Application Support/SketchUp 2025/SketchUp/Plugins/SketchUcation.rb:173:in `register_extension' /Users/USERNAME/Library/Application Support/SketchUp 2025/SketchUp/Plugins/SketchUcation.rb:173:in `<module:SCF>' /Users/USERNAME/Library/Application Support/SketchUp 2025/SketchUp/Plugins/SketchUcation.rb:17:in `<top (required)>' ------------------------------------ puts "\nDefault:\n#{Sketchup.read_default("SCF", "DefaultPlugins", "???")}";lp=SCF_Dialog.getMyPluginsFolders();puts"\nAll:\n#{lp}\n\nContents:\n";lp.each{|p|puts Dir.entries(p).size-2 };puts"\nRBs:\n";lp.each{|p|rbs=[];Dir.entries(p).each{|f| rbs<<f if f=~/rb$/};p rbs.length};puts; Default: /Users/USERNAME/Library/Application Support/SketchUp 2025/SketchUp/Plugins All: ["/Users/USERNAME/Library/Application Support/SketchUp 2025/SketchUp/Plugins"] Contents: 401 RBs: 204 => nil -
Can you both please try the text in the Ruby Console I prepared earlier...
You are using different operating systems...
But one thing you both have in common is your user-name is in capitals and starts with a U.
I'm assuming you haven't edited the text you posted...
There were reports some time ago about this kind of issue.
SketchUp's Ruby can see the /U in a string as a Unicode escape character - and this breaks the UTF-8 text format it's hoping to be using... Not sure if lowercase /u has the same issues ? Hence the encoding error message at the start...Can you try a change in your user-name to use all lowercase characters, or NO U after a / at all, restart your computer and try again ?
I'll look at ways of trapping this error, if it's possible... -
OK - I have not done anything in SketchUp for about 6 months. I updated Sketchucation Tools yesterday and have some comments/questions:
First of all, I think I accidentally/stupidly clicked on the Install like for some plugins yesterday. I do not know which ones they were other than Find and Report. So,
Is there a way to find out which plugins I installed yesterday?
How do you go about deleting/uninstalling a plugin?
I will have to get used to the new interface for managing the SketchUcation plugin UI but I think it will just require a little patience on my part. As an example, on the Bundles page, there is a Remove column, but I do not see any link to be able to remove one of the plugins on the list of plugins in the list. Am I missing something?
so far as i know, i have only 1 plugins folder, but here's the results for the code:
puts "\nDefault:\n#{Sketchup.read_default("SCF", "DefaultPlugins", "???")}";lp=SCF_Dialog.getMyPluginsFolders();puts"\nAll:\n#{lp}\n\nContents:\n";lp.each{|p|puts Dir.entries(p).size-2 };puts"\nRBs:\n";lp.each{|p|rbs=[];Dir.entries(p).each{|f| rbs<<f if f=~/rb$/};p rbs.length};puts; Default: C:/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins All: ["C:/Program Files/SketchUp/SketchUp 2025/SketchUp/Tools/gems/3.2.0/gems/matrix-0.4.2/lib", "C:/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins", "C:/ProgramData/SketchUp/SketchUp 2025/SketchUp/Plugins", "C:/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/skelion/rub_zip", "C:/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/skelion/plist", "C:/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/skelion/prawn/pdf-core-0.6.1", "C:/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/skelion/prawn/ttfunk-1.4.0", "C:/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/skelion/prawn/prawn-2.1.0"] Contents: 2 434 1 2 2 1 4 5 RBs: 1 153 0 1 1 0 1 1 => nil -
sorry the USERNAME is my text result replacement for my actual user name which i don't want on the Internet. if that is OK... i'm aware of the "u" problem...
the program data folder is from Podium where it has the temp files
- Is there a way to find out which plugins I installed yesterday?
Use the Filters dropdown and choose Installed
- How do you go about deleting/uninstalling a plugin?
Use Extensions > Extension Manager
You can't remove extensions from the current device's Bundle
@ntxdave
There's an Uninstall Manager dialog in the Extensions > SketchUcation submenu.
This renames the selected RB files RBX so that after a restart they no longer load, appear under the Plugins Manager dialog etc.
However, they are still there and can either be ignored, reinstalled using that manager, or manually deleted later.
To delete them open your Plugins folder and ensure that folder settings show file extensions.
Sort by Type so that all of the RBX files are together.
Delete them one at a time, noting the name so that you can also delete the associated folder - e.g. some_script1.rbx and its subfolder some_script1.
The Plugins folder is hidden by default - but there's a tool in the Extensions > SketchUcation submenu to open it for you... -
Thanks for the info - so it's probably not a Unicode /U issue ?
However, have you tried renaming your user-account in case ?
I'm assuming your Windows user-account name contains only ASCII characters and some limited punctuation, as instructed by Microsoft ? If you are unsure you can use the chat speech-bubble tool to PM it to me privately...We are investigating this because there are thousands of users without this error, so we need to do some detective work...
@TIG I have indeed edited (only) my user name from the original lowercase < tsur >
@tsur
Thanks for the update - so we can rule out an old Unicode /U glitch.
But what it might be otherwise is currently a rare mystery... -
@gullfo @tsur
Can you open the Ruby Console and Copy/Paste this in +<enter>
It lists the RB files you have in your Plugins folder and their text encoding within them - all of mine return UTF-8 but yours might not ??puts "\nFile Encodings...\n\n"; lp = Sketchup.find_support_file("Plugins"); rbs = Dir.entries(lp).find_all{|e| e=~/\.rb$/ }; rbsf=[]; rbs.each{|rb| rbsf << File.join(lp, rb) }; rbsf.each{|p| puts "#{File.basename(p)} = #{File.read(p).encoding.name}" }; puts "\n";Reply with the results...
File Encodings...
curic_deep_select.rb = UTF-8
clf_loose_to_groups.rb = UTF-8
MaterialResizer.rb = UTF-8
3DxSketchUp.rb = UTF-8
s4u_explode.rb = UTF-8
DM_ProfileBuilder3.rb = UTF-8
1001bit_freeware.rb = UTF-8
s4u_layer.rb = UTF-8
Slicer.rb = UTF-8
tt_cleanup.rb = UTF-8
3dshapestool.rb = UTF-8
DM_BoolTools.rb = UTF-8
!!Fredo6_LordOfTheToolbars.rb = UTF-8
s4u_frame.rb = UTF-8
TIG-Smart_offset.rb = UTF-8
TIG-Fracture.rb = UTF-8
tt_bitmap2mesh.rb = UTF-8
clf_random_painter.rb = UTF-8
s4u_copy_follow_objects.rb = UTF-8
5d_round_vertices.rb = UTF-8
curic_axes.rb = UTF-8
3dbazaar.rb = UTF-8
projection_extension.rb = UTF-8
asm_faceup.rb = UTF-8
clf_components_onto_faces.rb = UTF-8
curic_stretch.rb = UTF-8
ams_ClothWorks.rb = UTF-8
tt_edgetools.rb = UTF-8
dbs_animate_rotation.rb = UTF-8
Fredo6_HoleEditor.rb = UTF-8
curic_la.rb = UTF-8
Fredo6_TopoShaper.rb = UTF-8
su_solarnorth.rb = UTF-8
s4u_import_camera.rb = UTF-8
s4u_resize_texture.rb = UTF-8
ene_unfold_tool.rb = UTF-8
clf_extrapolate_colors.rb = UTF-8
DM_PlaceMaker.rb = UTF-8
clf_perpendicular_face_tools.rb = UTF-8
ene_uprightExtruder.rb = UTF-8
select_pp.rb = UTF-8
DBUR_DimTools.rb = UTF-8
vbo_mep_piping.rb = UTF-8
s4u_pickup.rb = UTF-8
as_flatten.rb = UTF-8
UnrealDatasmithSketchUp.rb = UTF-8
s4u_export_scenes.rb = UTF-8
s4u_delete_overlap.rb = UTF-8
Fredo6_Pic2Shape.rb = UTF-8
tt_vertex2.rb = UTF-8
curic_face_array.rb = UTF-8
Eclate_Deplace.3.0.2_EN.rb = UTF-8
as_scaleby.rb = UTF-8
curic_single_text.rb = UTF-8
ladb_opencutlist.rb = UTF-8
su_diffusion.rb = UTF-8
curic_section_view.rb = UTF-8
TIG-TextureTools.rb = UTF-8
cmd_auto-invisible_layer.rb = UTF-8
Fredo6_MoveAlignMe.rb = UTF-8
Fredo6_ToolsOnSurface.rb = UTF-8
Tax_Engineering.rb = UTF-8
rtches_IfcTag.rb = UTF-8
curic_paste_to_comp.rb = UTF-8
DM_zorro.rb = UTF-8
Fredo6_Curviloft.rb = UTF-8
5d_auto_info.rb = UTF-8
TT_SUbD.rb = UTF-8
s4u_scale.rb = UTF-8
curic_sun.rb = UTF-8
curic_mirror.rb = UTF-8
habitat_site_context.rb = UTF-8
ene_fractalTerrain.rb = UTF-8
Fredo6_MrHide.rb = UTF-8
dm_taper_maker.rb = UTF-8
Fredo6_FredoTools.rb = UTF-8
tt_uv_toolkit2.rb = UTF-8
s4u_curve_to_arc.rb = UTF-8
s4u_panel.rb = UTF-8
Roof.rb = UTF-8
s4u_crop_selection.rb = UTF-8
DM_Skimp.rb = UTF-8
Fredo6_FredoSpline.rb = UTF-8
Fredo6_FredoGuides.rb = UTF-8
curic_safeclean.rb = UTF-8
VolumeCalculator2.rb = UTF-8
lines2tubes.rb = UTF-8
ene_random_selection.rb = UTF-8
s4u_attach_to_face.rb = UTF-8
bezierspline.rb = UTF-8
ExtrudeTools.rb = UTF-8
DBUR_NumberingText.rb = UTF-8
ene_texturepositioning.rb = UTF-8
engineeringtoolbox_tools.rb = UTF-8
su_annotations.rb = UTF-8
as_randomtools.rb = UTF-8
s4u_slice.rb = UTF-8
curic_scene_manager.rb = UTF-8
Fredo6_FredoSketch.rb = UTF-8
s4u_connect.rb = UTF-8
DM_cutter.rb = UTF-8
curic_face_knife.rb = UTF-8
clf_color_by_slope.rb = UTF-8
Fredo6_Animator.rb = UTF-8
tt_shell.rb = UTF-8
DM_SketchUV.rb = UTF-8
asm_orienterexpress.rb = UTF-8
Bolt MakerXII.rb = UTF-8
clf_color_by_z.rb = UTF-8
SoapSkinBubble.rb = UTF-8
FixReversedFaceMaterials.rb = UTF-8
s4u_multi_slice.rb = UTF-8
tt_milling.rb = UTF-8
identic_ai.rb = UTF-8
curic_dim_scale.rb = UTF-8
curic_rotate.rb = UTF-8
s4u_align.rb = UTF-8
Fredo6_JointPushPull.rb = UTF-8
adebeo_pushline.rb = UTF-8
s4u_offset.rb = UTF-8
habitat_space_use_plugin.rb = UTF-8
s4u_hide_line.rb = UTF-8
ams_FixIt.rb = UTF-8
holygon_landshape.rb = UTF-8
jwm_shapes_loader.rb = UTF-8
s4u_makebox.rb = UTF-8
Fredo6_Curvizard.rb = UTF-8
s4u_importdxf.rb = UTF-8
tt_material_replacer.rb = UTF-8
s4u_weld.rb = UTF-8
su_sandbox.rb = UTF-8
su_extension_migrator.rb = UTF-8
PipeAlongPath.rb = UTF-8
get_dimensions.rb = UTF-8
s4u_linetool.rb = UTF-8
s4u_makeface.rb = UTF-8
tt_truebend.rb = UTF-8
ene_random_scale_and_rotate.rb = UTF-8
tt_material_tools.rb = UTF-8
lightbeans-plugin.rb = UTF-8
SKMtools.rb = UTF-8
clf_scale_and_rotate_multiple.rb = UTF-8
dp_flat_text.rb = UTF-8
s4u_find_gap.rb = UTF-8
su_dynamiccomponents.rb = UTF-8
SketchUcation.rb = UTF-8
s4u_tocomponents.rb = UTF-8
SU_Podium_V26.rb = UTF-8
s4u_divide.rb = UTF-8
curic_lengthsnapping.rb = UTF-8
s4u_linetoface.rb = UTF-8
s4u_reset_axis.rb = UTF-8
sj_batch_export_scenes_to_thumbnails.rb = UTF-8
dm_curve_maker.rb = UTF-8
ene_unroll_surface.rb = UTF-8
Mirror.rb = UTF-8
clf_shape_bender.rb = UTF-8
Helix-along-curve-tool-0.9.rb = UTF-8
s4u_filter_selection.rb = UTF-8
s4u_scaletool.rb = UTF-8
deBabelizer.rb = UTF-8
Fredo6_FredoScale.rb = UTF-8
fur_en.rb = UTF-8
tt_groups2comps.rb = UTF-8
smustard_DropGC.rb = UTF-8
s4u_paint.rb = UTF-8
curic_measure_pp.rb = UTF-8
Fredo6_ThruPaint.rb = UTF-8
tt_solid_inspector2.rb = UTF-8
tt_camera.rb = UTF-8
tt_text_editor.rb = UTF-8
curic_gizmo.rb = UTF-8
5d_library.rb = UTF-8
Fredo6_VisuHole.rb = UTF-8
TT_Lib2.rb = UTF-8
ene_solids.rb = UTF-8
Fredo6_!LibFredo6.rb = UTF-8
voxelizebeta04.rb = UTF-8
xformclone.rb = UTF-8
latticeMaker.rb = UTF-8
curic_axis.rb = UTF-8
TT_QuadFaceTools.rb = UTF-8
curic_se.rb = UTF-8
_jhs01_powerbar.rb = UTF-8
DM_Bevel.rb = UTF-8
s4u_transformer.rb = UTF-8
curic_align_view.rb = UTF-8
curic_teleport.rb = UTF-8
CAUL_Flowify.rb = UTF-8
as_shapestoolbar.rb = UTF-8
Fredo6_FredoCorner.rb = UTF-8
s4u_mirror.rb = UTF-8
flattery.rb = UTF-8
s4u_stair.rb = UTF-8
DM_SketchPlus.rb = UTF-8
!LordOfTheToolbars_seed.rb = UTF-8
dbs_move_rotate_open_close.rb = UTF-8
Architextures_SUExt.rb = UTF-8
clf_component_stringer.rb = UTF-8
TIG-DualDims.rb = UTF-8
5d_auto_measure.rb = UTF-8
curic_linepp.rb = UTF-8
ene_fog.rb = UTF-8
SLB_JWM_draw_angle_dim.rb = UTF-8=> nil
@TIG my user name starts with a "g"
lowercase. been in use for, oh, 25 years now on all systems... and Sketchucation plugin proir to 5 working fine.
